Dreaded Kernel Panic
singlefilerock
Dec 27, 2007
82
When you turn on your iPhone does it start scrolling white letters with a black background really fast? Then after its done turn off..act like its booting up again..then starts again?
Also this may apply to you.. when you turn it on it says connect to iTunes then it flashes blue? (I know this one is particularly scary because you'll try to boot into disk mode but it won't)
SOLUTION:
Simply UNPLUG FROM YOUR COMPUTER and plug into the wall. Boot into disk mode. [Hold down the sleep and home button until it shuts off..keep holding and it'll turn back on..KEEP HOLDING and after a few seconds it will say connect to iTunes or show a chord plugging into the iTunes logo.]
After you're in disk mode plug into your computer and RESTORE WITH iTunes.
Do NOT try to jailbreak a phone with ibrickr unless you have a 1.0.2 firmware.
After all this you may think, oh no! I have the 1.1.3 firmware now!
No worries! ZiPhone has made jailbreaking your phone easier than abc!
Here's a thread explaining it..it's incredibly simple. Even my friend who is computer illiterate got it!
http://forums.everythingicafe.com/t...-3-with-the-full-jailbreak-windows-mac.19789/
Bone
Feb 11, 2008
1,214
wow, that one does sound kinda scary.
themanofthedark
Jan 5, 2008
2,674
25
Boston
i had that happen to me when i was trying to use iBrickr to downgrade a 1.13 OTB to 1.02...
never doing that again..
i did it manually, through DFU mode...
(this was pre-ZiPhone)
eh, iBrickr isn't really useful anymore..
singlefilerock
Dec 27, 2007
82
not at all..
unless youre iPhone is in "ancient mode"
