Dumb question I'm sure, but how do I....? (keyboard question)
DeathBySnuggles
Jul 5, 2007
88
Tampa, Fl
I did a search but didn't find anything on this topic.
Scenario. I'm sending a text message. It's late in the conversation. I've just typed and sent my message. I want to read back to review the convo. How do I get the keyboard to disappear so that I have a full screen to work with, other than going out of the message and then back in? Possible?
gannon145
Jul 5, 2007
30
Melbourne, FL
I've been trying to figure this out too. The only thing I've found is to back out of the conversation to the list and then reselect it.
Kev1000000
Jun 26, 2007
234
You should be able to press anywhere on the conversation to remove the keyboard.
edit: nm, that doesn't work :p
alb0zf1n3st
Jul 2, 2007
624
tap somewhere on the screen should work
update..
sorry don't have mine with me i thought that would work ...
gcvt
Jun 21, 2007
1,029
San Francisco
This really is an annoying 'feature' - I text quite a bit and find it a waste of time to have to step back like that. Hopefully this will be addressed in future updates.
Mthoroughbred
Dec 16, 2008
751
102
43
All you have to do is scroll from center of screen or anywhere above the keyboard and scroll down and the keyboard will scroll allowing the screen to show just the conversation
Ledsteplin
Oct 29, 2013
4,853
1,000
68
Florence, AL
I tap the caret in the upper left corner to go back to the contacts list. Then tap the contact name again. It goes back with the keyboard at the bottom.
