Dumb question
dobymax
Oct 19, 2007
238
I know this is stupid, but how do you delete songs from the song list and an application also? The application is ESPN, but for some reason it doesn't work.
dcom
Aug 7, 2007
1,421
Suwanee, GA
Songs are deleted through iTunes only, you can't delete them from the phone.
Applications can be deleted by tap-holding their icon until they start wiggling, then tap the X in the upper left corner of the icon. They'll be put back on the phone the next time you sync unless you deselect or delete it from the list of apps in iTunes.
dobymax
Oct 19, 2007
238
Thanks gain guys. I have brain cramps today. :)
