DVD movies to iPhone?
tpeter
Jun 19, 2007
132
I think this may have been asked before but...
How do i rip one of my dvd movies and get it on my iPhone..
thanks..
sorry for being a nub.
dsuppa
Jul 3, 2007
208
New Jersey
www.dfsdesigns.com
thanks..
Go over to the iPhone Software Section and on the top there is a Tutorial there. If you don't like that software I would suggest CuCuSoft DVD to iPod, costs $30, but worth it in my opinion.
connie
Jul 11, 2007
2,839
105
So Cal
I use my son's program for his PSP. They sell it at Target for like $25. It converts your DVD to MP4 and then you just import it into your iTunes video file. It's called 123movie2PSP.
scottdirector
Jun 30, 2007
http://handbrake.m0k.org/
This is the best and easiest software I've used, and I've used it since the iPod video first came out.
Download this,
Set "Constant Bitrate" to 400,
Check the box next to "2-pass encoding" (takes twice as long, but ensures audio and video are ALWAYS in sync)
Click "Picture settings" and adjust the video for your iPhone's screen.
Make sure to click "Browse" in the upper right hand corner and rename and save the movie to an accessible folder.
Once that's done, open up iTunes, and drag the movie to your library.
After that's done copying, go to the 'video' tab of your iPhone's sync screen, and put a check next to the movie(s) you want on your iPhone, and click apply.
Voila!
tpeter
Jun 19, 2007
132
Download this,
Voila!
Where is that constant bitrate setting?
Also under picture mode what are the dimensions for the iPhone?
