DVD ripping help
LD3
Jun 29, 2007
I just ripped a DVD using handbreak and I can not get into iTunes. In iTunes I selected movies then add file to library, select the movie and noting happens...i don't see it in iTunes..what am i doing wrong? Thanks
petalmom
Jun 30, 2007
494
I just did it and it worked ok for me but I used Import.
File
Import
Locate your file and click on it
Click ok and it should be in the Movies library
reebs
Jul 11, 2007
146
Before you load movie onto iTunes. Are you able to play the movie on your desktop using quicktime? If you are, you shouldn't have any problems loading onto iTunes.
LD3
Jun 29, 2007
No , when i try to open w/quicktime it says "error-2048: this file is not a movie file"..i encoded with the mpeg4 setting
LD3
Jun 29, 2007
thanks for the help. I am using the windows version. I selected mpeg 4 do i need to select h.264?
reebs
Jul 11, 2007
146
not sure about windows, but on mac says only to seled "MPEG-4 video/AAC audio". do not select H.264 as your iPhone/ipod cannot play these.
reebs
Jul 11, 2007
146
also look at the thread for ripping dvd using pc on this forum
