DVD to iPhone 4. Help
Ryanz27
Jun 12, 2010
228
Minnesota
ok guys... im starting to have a migraine now. been seaching the web and trying to get this to work for an hour now. im gonna loose it soon. I have some DVDs that I own and i want them put into my iPhone 4. I cant for the life of me figure out a way to do it without having to buy a $30+ program. I tried using handbrake but it just sits at the "scanning..." stage and doesn't do anything. Can someone please help me with this.
Ryanz27
Jun 12, 2010
228
Minnesota
ok i got it to work now. but at the rate its doing whatver its doing it will takes hours... its at 2%.. and counting very slowly. This doesn't seem right. Also the file is already at 1gig and its not even halfway done...
Lon
Jun 5, 2010
2,946
132
Alaska
That doesn't sound right. I use something called PQDVD, which is an older Program - and wasn't free. But, I don't think any of my Full Length Movies are more than 1 gb +/-; and don't take any longer than about 20 min. to convert. Aside from that one I have very little experience with converting - it just does it. Someone in another thread mentioned another Program that assisted with implementation of Handbrake, but I don't recall what it was.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
There's another freebie called MakeMKV, although I use handbrake and/or mac the ripper.
Aug 22, 2010
24
I ended up getting WinX DVD Platinum. Works like a champ..... all for less than $30.
one_crazy_dude
Sep 13, 2009
460
72
Toms River New Jersey
You might be better off buying a program. I went with dvdfab and was the best thing ever. I click on iPod/iPhone tab and then click start. It does everything for you with free updates for ever.
Nov 25, 2010
Use free ripper, http://forums.everythingicafe.com/threads/how-to-transfer-mp4-file-to-iphone.15665/
X
xiaoa10
Guest
I used to use Handbrake, indeed, it is very slow but Free, Or you can try Aneesoft DVD ripper.I think the paid and popular one will works well.
Hope help you, Susam
