E-mail issue
slipperypete
May 20, 2007
205
I had no problems yesterday getting my accounts set up. I was able to receive and send e-mails, but today I can receive e-mails but I can't send. I keep getting a rejected by server error message.
Anybody else having this issue?
art
Jun 29, 2007
88
Mine has worked just fine from setup (yesterday at 7:30pm) through today.
What specifically are you having trouble with?
jstemp33
Jun 20, 2007
27
Art
Would you happen to know the easiest way to transfer my contacts from Outlook 2003 to my Yahoo email account?
Your thoughts would be appreciate!
wjp09
Feb 25, 2007
2,559
25
NJ
I got mine fixed but I can't help you guys out after spending about an hour being transferedwhen I went through trouble shooting and it suddenly started to work I'm not complaining though
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
mine suddenly started to work, too. Was having trouble with voicemail, but that worked about the same time. Maybe a congested network?
Ace4261991
Jun 18, 2007
530
yeahh i cant send any email through yahoo but i get email fine. i thought i was the only one with thie problem because i posted a thread abot it and no one said anything.. hm anybod knowhwo to fix this?
dirkslyder
If anyone can receive email but can't send email and want a quick fix solution
under smtp use att's smtp...
cwmx.com:25
If you are outside their network and try to use them for outgoing mail, they kick it back. They suggest using port 587 rather than the default 25
cwmx.com is AT&T's smtp server -- it will work if you are using EDGE, because that is an AT&T service, but note that it will not work whenever the iPhone switches to wifi.
Ace4261991
Jun 18, 2007
530
cwmx.com:25
i read that on the Apple site but it said to use that if you cant send emails with another email sevrer other than yahhoo aol gmail ect. and how do you get to smtp?
and also is eveyone thats having problems just getting error messages when they try to email or like me is it saying it sends the message but it never actually does?
dirkslyder
yes that is true, smtp section is the third column called out going mail under email account setup. I have godaddy mail thats why.
Ryukyu
Jun 15, 2007
101
Well that sucks.
Just got the same error message.
Is this something that can be fixed at some point or is it just something we will always have to deal with?
Is it an AT&T issue?
edgeit
Jul 2, 2007
ok so we need to switch the SMTP info everytime we switch from EDGE to WIFI?
what do we use when were on someone elses wifi connection.
dirkslyder
its an att outgoing server so if your not using att internet connection then it won't work. If your using someone elses wifi connection, all I can say is use web base mail or if you need to send something switch to EDGE right away and then go back to the wifi. Or you can call your email provider and ask for the smtp information and ports
lland
Jul 2, 2007
Email issue
I'm on the phone with Apple and they are aware of this issue. I hope to have some answers shortly.
For Outgoing Mail Server leave the User Name and Password empty. It does say it's optional.
LL
mikef1182
Jul 2, 2007
44
Add me to this list of people having sending issues. I get no error, it says sending than the message gos into no where. I only have this problem with yahoo, my work POP3 and .mac account work fine. I started having problems today.
iPhone-Planet
Jun 1, 2007
50
I never could send mail and just could receive it, that is, until I figured out what might have been the problem.
I went into settings, tapped on mail, then my account, then saw Host Name. It was set up as smtp.comcast.net. So I tapped on that to see what I might be able to do with it, and immediately it switched to pop3.comcast.net and when I went and tried to send my wife a message it worked perfectly.
Good Luck!
