"E" on the top left
GSA190
Oct 29, 2007
401
New York
I was looking at my cousions iPhone and their was a little E on the top right next to the ATAT. What is it?
GSA190
Oct 29, 2007
401
New York
Well I was right by a Wi-Fi network and it still had the E on the top.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Whose wifi? You just can't get on anyones wifi unless you log onto it. Make sure in settings that wifi section is turned on and also ask to notify you when in range of a wifi if you want to join. But they are always password protected.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Its my own wi-fi in my house.
Well then what are the security settings on the Router? You have to go into settings, under wifi and click to join or it should discover on its own and ask you to join, then enter your security settings.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Haha just checking, sometimes it seems as if the most obvious things are the ones you overlook the most. As the others have said, I would make sure that there are no firewalls associated with the router on the computer it is connected to and then making sure you enter the Network Key in exactly, try and be case sensitive specific as well.
kakofonix
Oct 2, 2007
596
Another thing you might want to check is whether your router has Wireless SSID Broadcast enabled. If it's not, no new clients, including your iPhone, will detect it.
