Earphone jack iPhone 5
Prozium12
Jan 22, 2012
352
35
Uk,Manchester
Couldn't Apple do away with the earphone jack and have them plug it into the lightning dock connector port ,in fact couldn't all phones do this ok most Android phones still have the earphone port on the top of the phone but now that Apple have moved theres to the bottom couldn't this be done..
Sent using iCafe app
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
Then you couldn't charge your phone and simultaneously listen to awesome music, like this song:
...Unless someone invents an adapter like this, but much smaller and more elegant (not my picture):
5,578
There's more to it than just losing the ability to charge while listening to music through headphones. The headphone jack is universal and works in all different types of devices. If they were to make Apple earpods fit in the Lightning charging port, they would have to redesign the earpod jack to look exactly like a Lightning connector. While it might be possible to engineer a charging port to work as an audio jack, it's a bad idea because we would lose compatibility with all different types of headphones and we would then be limited to Apple earpods and those earpods would work in nothing except the newest iDevices. That is until Apple comes out with a $29 Lightning to audio jack adaptor that we would have to carry with us. No thanks. It's not worth the small amount of space it would save.
JON35Y
Oct 16, 2012
87
In addition to losing the ability to charge while listening to music through headphones, the headphone jack is universal and works in all different types of devices. If they were to make Apple earpods fit in the Lightning charging port, they would have to redesign the earpod jack to look exactly like a Lightning connector. While it might be possible to engineer a charging port to work as an audio jack, it's a bad idea because we would lose compatibility with all different types of headphones and we would then be limited to Apple earpods and those earpods would work in nothing except the newest iDevices. That is until Apple came out with a $29 Lightning to audio jack adaptor that we would have to carry with us. No thanks. It's not worth the small amount of space it would save.
Shhhh, don't tell Apple that! You know they're gonna try and pull a stunt like that sooner or later. :)
talon90
Jan 17, 2009
290
29
They certainly can, in fact the technology is all ready present in the former 30 pin and current 8 pin lightning connector. It is the same technology that allows you to connect your phone to your car, various docks and speakers and play music. The question to me is, why would you want that? I like the ability to use the now universal 3.5mm jack and plug in third party headsets and earbuds or use a plain old 3.5mm cable and plug in to other audio peripherals and car connection kits. The last thing I want is for Apple to reinvent the wheel (again) and render all of my remaining accessories obsolete.
liberated
Jul 19, 2007
3,238
488
You could do this the other way around and just use the regular headphone jack for data transfer and audio like the old iPod nano, tho transfer speeds may be compromised.
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
I don't think you could charge the iPhone via the headphone jack.
