Easy n00by question...
jimmy_hat
Jan 19, 2008
145
UK
I've doen the jailbreak 1.1.3 thing and I've decided I don't like it and want to go back to jailbroken 1.1.2. But iTunes now makes you update to 1.1.3, so how would you update to 1.1.2 after you've jailbroken 1.1.1 and installed oktoprep?
enigmanic
Jun 27, 2007
513
As long as your phone is OTB 1.1.1 and lower, you can follow either of these guides to get back down to a jailbroken 1.1.2 with service:
http://www.hackthatphone.com/113/iPhone_downgrade_113.html
http://www.modmyi.com/forums/showthread.php?t=25695
jimmy_hat
Jan 19, 2008
145
UK
Oh dearie me... my iPhone was 1.1.2OTB... but thanks I'll check the guides out and update here depending on what i decide to do.. :D
Oh yes I found it if anybody is in the same boat as me you need to restore to 1.1.1 as per jailbreak guides, use ibrickr blah de blah and then when you have to update to 1.1.2 hold down option/shift and install 1.1.2.
The 1.1.3 soft update doesn't touch the baseband so theres no need to downgrade that.. thanks for the links.
