EASY WAY to have NEW SMStone for 1.1.1
theone77
Oct 18, 2007
73
1.we need a caf file for the tone...
USE ibrickr ---->this will convert your mp3/wav musicfile to .caf and store a copy in your ibricker folder on your computer.
2. in ibrickr---->click sounds/sms alert (received) then add mp3/wav file u want to convert to caf
3. then go to your ibrickr folder(in your windows explorer) and u will see your converted .caf file
Open your ibricker folder and rename the file to one of the following:
sms-received1.caf
sms-received2.caf
sms-received3.caf
sms-received4.caf
sms-received4.caf
sms-received6.caf
4.then log on to winscp and place the file into:
System/Library/Audio/UISounds (you can make a back up of the original sms-received file if you like)
Replace the original file in the folder with your new and your favorite smstone u converted to caf file, don't forget to rename.
here are some of .caf file(SMS tone) now...just rename and put in the folder mentioned above
Sep 14, 2007
yes it works for 1.1.2 also. I have also added a good tone to my installer source if you want to try it.
  1. Open installer, and tap Sources, Edit and Add.
  2. Type in http://limitededitioniphone.com/lei.xml and Ok then Done.
  3. Now tap on Install at the bottom and scroll down to the Sounds category
  4. Install TwinkleSMS
  5. When done installing, make sure to switch your tone to Electronic
