Edge Connection HELP - Live in Canada using Rogers Wireless? any different?
Nov 29, 2007
I have my iPhone unlocked and its working awesome. ihave just spend the last 3 hours trying to get Edge to work with NO luck.
is there a way to do it, is it different because i am in canada?
can anyone help me out?
im not sure if ineed a specific service from my provider or maybe its just a setting in the phone.
anyone? thanks
greenjbhsd
Jul 13, 2007
571
Not sure what you are experiencing there. I can say that I have my phone activated in the US and when I went to Vancouver it connected to the Edge network just fine. The part of this I am not sure about is the unlocked phone, that seems to make things unpredictable in some cases. Hopefully this bump will keep it on the first page for you.
Nov 29, 2007
thanks, i appreciate the thoughts.
has anyone else even got an unlocked iPhone in Canada on here?
Nov 11, 2007
I have an unlocked iPhone with Rogers.
Settings are:
APN: internet.com
username: guest
password: guest
I'm on the 65$/1gb a month and it's working great!
And you should install from the installer "EDGE settings fix" so the settings won't reset everytime you turn off your phone.
KD
Nov 29, 2007
thanks for the help I appreciate it. I have pay as u go now and thought I would try load up a webpage so I opened a web forum and one page took 6 dollars!yikes. Glad it works but I won't be using until I get a plan.
