Edge Icon and Time Color
Jul 19, 2007
Is there any possibility to create an Edge icon thats different in color or even in size? Has anyone attempted to change the actual time on top of the main screen?
alb0zf1n3st
Jul 2, 2007
624
I don't think its gunna be possible to change the time.. maybe font maybe? ... I have changed the service bars ,lock, little battery on top right and wifi ... my edge Icon is Red now.. so it is possible
DiBxna
Jul 18, 2007
43
in scottsdale, AZ
www.myspace.com
we have everything hacked man, the color of your signal strength, the icons, obviously the ringers and carrier logo, battery color, the icon on the slider for unlocking the screen and the one for turning off the phone, the bar where the phone, mail, safari, and ipod icons are, literally everything.
maybe ill get unlazy and post tutorials, but if youve been able to follow the amazing tutorial already posted for how to do custom ringers, you should be able to figure out from there how to change everything else (just look at the extensions for the other files in the different iPhone folders)
DiBxna
Jul 18, 2007
43
in scottsdale, AZ
www.myspace.com
yeah i got the service bars, wifi, bluetooth and battery already changed, i just didn't see anything on the location of some of the little stuff
well the font of the battery could be changed... however you'd have to find a full set of fonts and save it as a .ttf file and place it in this folder: /System/Library/Fonts/Cache and the problem is figuring out which text file to replace... theres about 30 lol... the most obvious text files are lockclock which i can only assume is the font of the clock as it appears when you are in screen lock mode... that would likely be your easiest first attempt (just use the getfile /System/Library/Fonts/Cache/LockClock.ttf command in iPhoneinterface before you attempt to change it so you can restore your default file if you don't like the outcome)
let me know if you decide to try this out... if someone would be willing to get me a font set that is in a cool font I would be happy to try it out and post my results.
