EDGE is not really bad
alpha_omega
Jul 19, 2007
My speed was 156kbps. I don't have many complaints on the EDGE network. When the first reviewers reviewed the phone, I was really worried about the speed. I was pleasantly surprised.
xSoNiCcRaCkErSx
Jun 30, 2007
226
You can actually speed up the edge connection 5x as fast as it normally is by going through google's proxy and loading pages that way, its a lot more time consuming and ineffcient but it really does speed up your connection. You can do this by going to http:www.google.com/m which is googles proxy for mobile phones and iPhone and check the box that says optimize pages for mobile use. Then search all your webpages through google and I will guarantee you you will see seemlessly faster speeds.
Napoleon Dynamite
May 20, 2007
103
30
Turin, Italy
www.connessionegratuita.com
So you can set the proxy as your homepage and you're done?
thesaint
Jul 9, 2007
341
DFW
I was using the same method as mentioned above when I was using 6682 and it works really gr8.
