EDGE Settings
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
How do I get to the EDGE settings on my iPhone?
I got to: Settings -> General -> Network, and I only see: VPN & Wi-Fi options, not EDGE (like others state). Am I missing a menu option here?
Thanks.
termleech
Sep 7, 2007
1,154
McPherson, KS
Thanks.
What EDGE setting are you talking about?
The only other option that you should see under General -> Network is to turn off Data Roaming.
If you want to turn on and off EDGE, then download and install Services from Installer.app. It will allow you to turn on and off EDGE as well as other services like SSH.
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
On my old 8925 (seems ancient now), I could set the network settings to use on AT&T. You know, like medianet etc. Say if I switch my SIM to T-Mobile, where exactly would I put their network settings?
