Edge Settings
jt60
Dec 14, 2007
Originally Posted by jt60
Greetings,
I am a new member and user of iPhone ver.1.1.1(3A109a) Unlocked.
I have found the settings (APN, ID, PWD) on the Edge do not save. They are emptied after going back to the Home page, Effrorts to reset the phone didn't work.
Could anyone kindly help? Thanks.
Try the iPhone Software forum instead. This forum is more for general iPhone questions while the Software forum is more for hacking and unlocking.
phillyphill39
Dec 30, 2007
146
where do you see these settings at? i've yet to come across them i no option to change my edge settings anywhere.
jt60
Dec 14, 2007
On your Home page, where you see all the icons, like Safari, Ipod, Caculator, Calendar etc. Click on the icon Settings, and go on from there.
meiphones_brill
Nov 16, 2007
797
The ability to edit edge settings has been taken away in 1.1.2
meiphones_brill
Nov 16, 2007
797
oh aight no wonder i cant find it.
You can doctor it up...
/System/Library/Frameworks/CoreTelephony.framework/Support/UnknownCarrier.plist can be edited and used to make your settings real nice
Fill in the blanks - and upload, it's magic. Here's my O2_UK.plist - If you're on O2, this is hot to trot. If not, you can probably guess what to change. You will need to know your carrier's Country Code (MCC) and Network Code (MNC) as they're in there too.
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>BookmarkURLs</key>
<array>
<dict>
<key>BookmarkName</key>
<string>O2</string>
<key>BookmarkURL</key>
<string>http://www.o2.co.uk/iPhonestart</string>
</dict>
</array>
<key>CarrierName</key>
<string>O2</string>
<key>IntlDataRoamingSwitch</key>
<true/>
<key>MyAccountURL</key>
<key>MyAccountURLTitle</key>
<string>O2</string>
<key>ShowCallForwarded</key>
<false/>
<key>ShowCallForwarding</key>
<false/>
<key>ShowTTY</key>
<false/>
<key>StockSymboli</key>
<array>
<dict>
<key>symbol</key>
<string>^FTAS</string>
</dict>
</array>
<key>SupportedSIMs</key>
<array>
<string>23402</string>
<string>23410</string>
<string>23411</string>
</array>
<key>SupportsNITZ</key>
<false/>
<key>VisualVoicemailServiceName</key>
<string>IMAP</string>
<key>VoicemailPilotNumber</key>
<string>901</string>
<key>apns</key>
<array>
<dict>
<key>apn</key>
<string>mobile.o2.co.uk</string>
<key>password</key>
<string>password</string>
<key>username</key>
<string>vertigo</string>
</dict>
<dict>
<key>apn</key>
<string>wap.o2.co.uk</string>
<key>password</key>
<key>username</key>
</dict>
</array>
<key>com.apple.voicemail.imap</key>
<dict>
<key>AuthenticationScheme</key>
<string>DIGEST-MD5</string>
<key>BeaconAddress</key>
<string>9011</string>
<key>ClientManagesTrash</key>
<false/>
<key>DataContextIdentifier</key>
<integer>1</integer>
<key>GreetingNotification</key>
<true/>
<key>MaxGreetingDuration</key>
<integer>60</integer>
<key>MaxPINLength</key>
<integer>10</integer>
<key>MinPINLength</key>
<integer>4</integer>
<key>UsesSSL</key>
<false/>
</dict>
<key>voicemail_context</key>
</dict>
</plist>
firewire
Nov 4, 2007
941
17
What does editing the EDGE settings accomplish? What can you change that will amount to something tangible?
meiphones_brill
Nov 16, 2007
797
if you haven't unlocked and switched network, then no benefit at all. If the phone is being used on a network it doesn't know about, a change in the settings may be needed to make things work.
