Edge Speed
oldertwin
Sep 5, 2009
I have a 2g iPhone on att go phone plan with data and the internet is so slow..
I went to a website called iPhone network speed test and my iPhone gets right now 32kbps. And is that normal? What speed are you getting on edge with your iPhone? What can I do about the speed?
psylichon
Oct 31, 2007
16,591
751
41
Philly
No, that's pretty slow. Where are you located? Right here in Philly, on my 3GS (with wifi and 3G turned off), I'm getting 174kbps.
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
Seems slow to me too. Just tested the EDGE and it was 171 kbps.
It definitely depends on the AT&T coverage in your area so that could be affecting your speeds.
