Edge's Setting
jt60
Dec 14, 2007
Greetings,
I am a new member and user of iPhone ver.1.1.1(3A109a) Unlocked.
I have found the settings (APN, ID, PWD) on the Edge do not save. They are emptied after going back to the Home page, Effrorts to reset the phone didn't work.
Could anyone kindly help? Thanks.
Chris716
Nov 29, 2007
807
IL
are you using att... or are you unlocked running on some other gsm network..
jt60
Dec 14, 2007
Thanks for your prompt reply. I am using other GSM network. It worked for a while, then the setting just went blank.
Chris716
Nov 29, 2007
807
IL
i wish i could help you but im not sure im sure somone will come along real soon and help though...
tiguy99
Nov 28, 2007
154
Chicago
Anyone know where the DNS settings are for EDGE? I want to manally enter them in like I did on my T Mobile DAsh and Motorola q. Adjusting the DNS settings to
208.67.222.222
208.67.220.220
Actually speeds up the connection about 40%! Just want to know where to input them
Welcome to the forums!
I don't know zip about unlocking, so I won't be of much assistance.
- John
phillyphill39
Dec 30, 2007
146
how do you get to the settings to change them, i don't have that option on my phone.
phillyphill39
Dec 30, 2007
146
Thanks but it doesn't work. Ill just start a new thread possibly but its not that important to me. I really have no need for it.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Greetings,
Try the iPhone Software forum instead. This forum is more for general iPhone questions while the Software forum is more for hacking and unlocking.
