Edit photo on 4S but uploads to photobucket as original?
MuddyPaws
Oct 3, 2009
986
31
I took a pic, edited it....cropped it. Then went to the photobucket app and uploaded it. But when I look in photobucket, it's uploaded as the original picture...uncropped. I can't even see the original picture on the 4S camera roll.
Anyone else notice this?
Is there a fix? I mean besides, reboot, reset, restore?
MuddyPaws
Oct 3, 2009
986
31
Rugaby's advice was actually very good. I have had to reinstall my Photobucket app multiple times due to various problems. The app is a little buggy.
If the image has been cropped, and saved, and the original non-cropped image is not visible in the camera roll...
MuddyPaws
Oct 3, 2009
986
31
If I resize it with simple resize, and then save it as a new file, then it uploads correctly.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
I've also had to delete and reinstall photobucket a couple of times due to it being wired. Always fixes the problem for a while.
Guess good advice isn't desired. So I will go with smart Alec.
Have you tried a restore? Or perhaps a hard reset?
MuddyPaws
Oct 3, 2009
986
31
I have never had a problem with photobucket. Now I see it is doing the same thing with flickr and with the attach pic function of forums.
RoofMonkey
Jun 21, 2010
8,921
1,983
Just checking so I can try to duplicate this. You take a photo, crop it using the feature on the phone. You go to attach it to a forum, like here, and it actually sends the original?
MuddyPaws
Oct 3, 2009
986
31
That's what I am running into. After resizing it with Simple Resize, it works fine. Just when it's cropped and saved with the stock photo app am I seeing this. Kind of odd. Never tried to do it before.
What's also odd is that I can take a screen shot of the cropped picture and it looks right when uploaded to photobucket or flickr.
