eiC app keeps asking for login and password
Daking618
Oct 31, 2010
112
Miami Fl
I know someone may have ask this. But ever time I launch the app it requires me to put in my username and password. Is there anyway to bypass this. Because it really gets annoying to continuously have to put in the username and password.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
The new update, that will be out soon, will fix this problem. For now if you close the app or turn off your phone it will require you to re enter your info.
canamera
Dec 28, 2009
2,756
79
44
Toronto Ontario, Canada
I closed it, and deleted it from the multitask bar too....when I click on it again, it just takes me to dashboard....just tried it a couple of times....always works fine.
RoofMonkey
Jun 21, 2010
8,921
1,983
Maybe that's what really happened to Chris and caused his absence from here. Shut down app and couldn't remember his password. Hehehe
Sent from my iPhone4s using iCafe app
  • Like
Reactions: canamera
RoofMonkey
Jun 21, 2010
8,921
1,983
Ya know, that's a good question. I can't find it either. Hmmm
Go to app store and search for
The app. If it says an update is available, your probably on 1.7
Anyone else have an idea to
Check App version?
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Check App version?
I can't find it but app store will tell u update.
RoofMonkey
Jun 21, 2010
8,921
1,983
Settings somewhere tells you what version of all your apps. Or iTunes when plugged in.
Forgot that's listed in iOS 5. Settings, general,usage. May have to
Tap list all apps. Give space used and version.
