EIC Logs me out?
Booyow1204
Jul 14, 2010
595
40
Las Vegas
Don't know if I'm late on this one, or if it's already been mentioned and I just missed it.
My issue is the app logs me out when I quit the app (usually when I kill the app from my background).
If I exit and go back in w/out killing the app from my multi-task bar I don't notice a problem. But I kill programs on my bar to keep my battery as well as prevent all the things running in the background and slowing me up.
Has anyone noticed a similar issue or a bug I'm not aware of here? Or is it something w/just me?
15,385
1,023
I can't imagine killing every one of the apps I use from the multitask bar. I never bother unless I need to restart an app due to a bug.
  • Like
Reactions: Europa
Agreed. With the exception of Navigon, I only close apps in the task switcher if I'm experiencing a problem with one of them.
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
version 1.8.1 is due out very soon to address that issue.
Chex
Dec 17, 2008
592
PA
If you move your thumb up and down over the first one, they move over rapidly and you can close them all in secs.
My phone slows down when the RAM gets below 100MB, which happens after the apps add up.
Sent from my iPhone 10
Booyow1204
Jul 14, 2010
595
40
Las Vegas
Ok cool, I wasn't sure if it was just me cause I noticed it happening the other day all of a sudden.
Ill just keep this app in the background so I don't have to keep logging in...I'm too lazy for that. :p
iphonewarrior
13,847
699
The eiC app updates usually take around a week. Myself and Honda have tested the latest build(s) and in my opinion, it's very stable and the login problem is fixed. As always your mileage may vary.
