Elite 8 theme questions
ironlungakc
Aug 26, 2007
94
Hi.
I installed this theme.
When going through the options with winter board, there are a ton of different options. How do I know what each one does? Can't always tell from the file name.
thanks.
28,365
5,507
Hi.
thanks.
Apply a couple and respring to test them. Then go back, remove them and test some others. The e8 base is the icons. Most of the others are docks, alternate clock icons and status bar elements (cellular and WiFi symbol, battery, etc.). e8 UI has more extensive system-wide changes.
