Email crashing
Status
Not open for further replies.
jareknyc
Aug 27, 2007
715
NYC
Email is crashing this morning did, hard reset, did reset all settings, cleaned up that menu when u click twice home button, made sure all is clean from there...I even try to go to pic and try to email one and it asked me to add a email when I did put one in there, it says already exists...then I tried removing or disabling mail box nothing helped...it worked last night
jareknyc
Aug 27, 2007
715
NYC
And I just found out that safari will crash 2
Dec 15, 2008
5,386
340
Pensacola, FL
Hello. What iOS are you on? Have you thought about doing a full restore? How long has this been occurring?
jareknyc
Aug 27, 2007
715
NYC
7.0.4 jail broken trying to stay away from full restore, it happened this morning
Dec 15, 2008
5,386
340
Pensacola, FL
Sadly, I have the same issues. Certain apps crashing. If it continues to crash for me back to back to back, I will delete and reinstall that app and that helps temporarily.
Obviously I can't reinstall safari or mail. But other apps I can. You're saying a hard reset and respring don't help?
jareknyc
Aug 27, 2007
715
NYC
Didn't try respring how do I do that?
Dec 15, 2008
5,386
340
Pensacola, FL
I don't have sbsettings
You can get it from Cydia. It is a great tool. If not, there is also a quick respring app button in Cydia.
Respringing can solve or at least help a lot of issues.
With your original post, is mail still crashing or are you unable to email/add account?
28,365
5,507
Do you have any Cydia email tweaks?
jareknyc
Aug 27, 2007
715
NYC
None, I always stay away from Tweaks except tethering for my iPad and laptop
28,365
5,507
Did you install anything in Cydia yesterday before this started happening?
Dec 15, 2008
5,386
340
Pensacola, FL
I still have certain apps crash on iOS 7.0.6 and I don't have a crazy amount of things on Cydia anymore. I only see crashes every few days. How about you?
jareknyc
Aug 27, 2007
715
NYC
No just talked on the phone for 1 hr went to sleep listening to music and it died after 1 hr charged it this morning and safari and email is crashing
28,365
5,507
Are they both crashing every time you try to use them? Random Safari crashes are normal on 7.0.4, but it shouldn't crash every time you try to use it. If it's just once or twice a day, I wouldn't worry about it. The only fix would be to update to 7.1, but you don't want to do that because you'll lose the jailbreak.
Dec 15, 2008
5,386
340
Pensacola, FL
Yeap I can't turn it on at all
You can't open Safari or Mail period anymore? If that's what you're saying, well then updating may be the fix unless Apple can make a suggestion. I have had the same issues you've had, but a simple reboot helped fix it.
jareknyc
Aug 27, 2007
715
NYC
Will not work period tried everything above
Status
