Email not being "pushed"
patcar
Mar 14, 2011
Anyone having an issue with Ipad 2 not "pushing" email through? If I open the email app, all emails will come through, but otherwise, it never notifies me of a new email. I checked my email settings to make sure I had it set to "push", and I did. Any thoughts or solutions?
RoofMonkey
Jun 21, 2010
8,913
1,979
May be a silly question, but even with Push activated, did you check to make sure it's not set to manual?
Image has been removed.
llrickman
Jan 12, 2008
787
26
Albuquerque , NM
On mine my me.com email always pushes fine but I have Att uverse and my email there never does. I've checked everything and can't figure out why it won't
Sent from my iPhone 4 using iCafe app
patcar
Mar 14, 2011
RoofMonkey, I think you are right. Although it said "push" on the menu, I actually never went in and make sure it was "on". Can't wait to have the chance to do so! Thank you!
RoofMonkey
Jun 21, 2010
8,913
1,979
No problem, hope that's the easy fix for ya!
coop1701
Jun 30, 2007
899
114
43
That's odd. I have never set a push account to anything other than manual RoofMonkey. I push 3 email addresses too. My AT&T, Work and MobileMe.
patcar
Mar 14, 2011
Well, I went home and made sure I adjusted all the settings for my email to get "pushed" and it still is not working. I don't know if this has something to do with AOL and Gmail or what the issue may be :(. May have to take a trip to an Apple store soon.
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
Do you really need them pushed to your iPhone? I do mine all manually, to conserve battery power.
patcar
Mar 14, 2011
I have them "pushed" on my iPhone no problem, but for some reason it does not work on my ipad 2.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
I have my yahoo account in my phone. Always have. About a week ago I stopped receiving emails.
The only time I get them is when I actually click on the email app and it says checking for email then downloading whatever new messages exist.
I deleted the account off and re added it. Same problem. I deleted the account off did a hard reset re added it and same problem. I switched to fetch for about a day and half and that work then went back to push and same problem.
This problem exists in and off of wifi also. Not having any other problems. Getting texts and everything. Getting all my emails. Just requires me to make the app fetch them.
Is this a server or carrier problem?
Any ideas will help. Is getting annoying.
Jmbaker429
Jun 28, 2010
994
144
34
It sounds like you have done everything as far as the phone goes. Do you have another email you can use to see if they will push from another account. Like gmail? I would say if you could test it and it doesn't push then it's your phone and if it does push then it's a yahoo problem. I am leaning towards the side of it being a phone problem. Because if emails are downloading manually then I would think the server is performing ok and allowing the phone to download emails. I think it's the phone acting up and the push feature has a malfunction.
There is an iOS 5 bug with Yahoo that causes it to not push at times. Some people have said that adding an @me email to the phone fixes it.
Jmbaker429
Jun 28, 2010
994
144
34
just having the @me account on the phone allows the yahoo to work better? Just making sure that's what you meant. Also I did have email buggy problems whith IOS5 also.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
If it is an ios5 thing why did it randomly just start with me then. Actually. Sob. I did a sync the other day. About same time it started now that I think about it. Didn't update iOS or anything but wonder of that triggered it.
What is an @me email? And your saying have two accounts on the phone?
MobileMe was a paid service for several years. Now it's free with iCloud. Yeah, I have two email accounts on my phone. Gmail and @me.
