Email not downloading automatically
Niamh
Jun 6, 2011
I'm having this weird email problem....all my email addresses are set to 'Push', so that they're supposed to automatically download to my inboxes, as soon as possible! Without me checking every time! I deleted the email addresses and set them all up again, but the problem is still there.
Help! :eek:
Niamh
Jun 6, 2011
Oops sorry! :oops: The problem is that the email doesn't come in automatically. Even though I have set each individual address to 'Push'.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
check under advanced and make sure they are also set to push in there.
What firmware are you running and on which iPhone?
raqball
Jan 30, 2011
1,079
198
So. California
When set to push they should come in automatically...
If set to fetch then the time frame needs to be specified..
I am also having issues with push.. Search Google and many others are as well.. Email not getting delivered until the mail app is opened..
I am having this issue with Yahoo mail and .me mail
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Mines come in fine, I only have gmail set to push thou.
Reset your network settings, see if that helps.
shutter13
Jan 8, 2009
2,209
153
What domain are the email addresses? Unless things have changed...not all domains will push email to your device.
showguy
Dec 2, 2007
769
Long Island, NY
I have always found that even with it set to push you need to make sure manual is not selected. Sounds weird but thats how it always worked for me.
Niamh
Jun 6, 2011
Thanks everyone for your advice. I am aware of the Advanced option to set it to Push, rather than Fetch or Manual. I've set them to Push too. :-(
