Email options to conserve battery?
arlan
Jan 10, 2008
40
okay, so like, i need to have my EMAIL thing stop checking for new email every so often.
just to conserve battery..
are there options doing that?
i use yahoo :D
psylichon
Oct 31, 2007
16,591
751
41
Philly
Yeah, turn off push email for your Yahoo account (in the iPhone's mail settings) and then set it to only check manually.
xcissexc
Aug 9, 2007
501
no but what you could do is go into setting and keep your account turned off. then when you need to check for mail go back into settings and turn your account back on and then check for mail. i would get very annoyed by this process but thats the only think i can think of that would help you. you must use your phone non-stop if you are that desperate for tiny bit of extra battery life you would get from having your mail app not check for mail as often.
EDIT: well psylichons method seems much easier than mine, never played around with my setting enough to know that all those settings exist lol
psylichon
Oct 31, 2007
16,591
751
41
Philly
What are you guys talking about? Am I missing the point here? It's easy to turn off automatic mail checking.
Or wost case scenario, use Bossprefs to turn off the edge and wifi antennae... you won't have any problems then.
But really, why not just turn off auto check in settings?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
arlan - I'd suggest in future you should come up with *much* better post titles if you want help.
Right now, while it's super quiet, you got a pretty quick answer - but when the forum is busier it is really unhelpful to use over the top, melodramatic and vague post titles when seeking help. Try saying 'Help with Mail Settings' or anything that gives a hint about what your actual issue is.
I hate the thought that when things are busier, there will be tons of posts with similarly vague titles ...
psylichon
Oct 31, 2007
16,591
751
41
Philly
That is a very good point. If the OP truly feels near death due to this issue, they have more and bigger issues than we can really address in this forum.
arlan
Jan 10, 2008
40
i can't find that option in my settings. :(
arlan
Jan 10, 2008
40
It should be under Settings / Mail / Autocheck - set it to 'Manually'
there is no autocheck..here ill show u what's under mail..
Accounts
asldfjalsdf_j@yahoo.com >
Add Account... >
Messages
Show 50 Recent messages >
Preview 5 Lines >
Minimum Font Size Medium >
Show To/Cc label [off]
Ask Before deleting [off]
Sending
Always Bcc myself [off]
Signature Sent to my iPhone >
Default Account asldfjalsdf_j@yah... >
THAT'S all it's showing.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Have you gone into Yahoo mail at top of that screen and under Advanced set Use Push Email to Off ? I added my Yahoo account and once I set that to Off, I defintely see the Autocheck setting
arlan
Jan 10, 2008
40
Okay i got to ADVANCED and it says PUSH MAIL i turned it OFF.
but i can't find that AUTOCHECK setting.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
That's really odd. Do you only have a Yahoo account setup? If so, maybe setup a dummy Gmail account - even if it is not a real one. Do that and see if afterwards that setting appears under mail settings - as it should by default ...
