Email taking LOOONG to send NOW.
mm1250
Jun 23, 2007
81
HEllo,
I updated to the new version and I noticed that when sending email it takes almost 50-60 seconds to send. It just sits there saying "sending" on the bottom than it sends right away afterwards. It wasn't doing this before the update. This happens both on Edge and wi-fi
Getting email is working fine..
Also, I see that part of the update now shows all my "Exchange" mail folders vs before it was just showing the inbox, which is good.
iPhobos
Jul 25, 2007
201
This could have something to do with your firewall. Do you have ports set up on your email accounts? If you do then make sure they are open on your firewall, both on your computer and on your router.
Don't know if this helps but its something to check until someone can give you a more definitive answer.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Are you sure it's not when you are just on the EDGE network? On mine, I've noticed the keypad is much slower when using EDGE vs. Wifi.
mm1250
Jun 23, 2007
81
IT does this on both wifi and edge. I mean it works but it takes almost a minute to send. Before it was almost instant.
The Apple
3,105
Indiana
have you tried to close the mail application and then restart it?
or have you tried a soft reset or a hard reset?
T
TurboSC
Guest
It's definitely EDGE. AT&T needs to catch up to the Apple standard.
