End all program's
jo12jt1
Apr 3, 2010
69
Is there a program that allows you to close all program's at the one time I no there is activator but it does not have that option on it
Sent using iCafe app
RoofMonkey
Jun 21, 2010
8,891
2,057
I use SBsetting with the remove background toggle. Auxo also has this feature
28,405
5,535
There's also WeeKillBackground. It adds a 'Tap to close all apps' to Notification Center.
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
Not unless you are jailbroken... The two above solutions should work nicely if you are, though ;)
28,405
5,535
Three. :D He OP mentioned Activator, so we know they are jailbroken. I'll move the thread to Cydia apps.
iphonewarrior
13,847
702
Seven. Submerge in water for 30 minutes. :D
KeziaPurrs
Mar 18, 2013
86
22
Houston, TX
I submerged mine in water for only 5 minutes and it closed all the apps. Every single damn one of them. LOL
jo12jt1
Apr 3, 2010
69
Many thanks folks ! The one that I was thinking of was remove background , I just couldn't mind the name and couldn't find it using the search engine so once again many thanks to all
iphonewarrior
13,847
702
30 seconds would probably have a similar effect ;)
