Error 1064 In iTunes - iPhone won't restore
barrycompston
Nov 29, 2007
Hi
Have a iPhone 1.1.1from the usa.
It shows the cd/lead logo like when you but at first.
Tried using iTunes to restore to 1.0.2 - i get Error1
Tried using iTunes to restore to 1.1.1 - i get Error1064
Tried using restore in iTunes - i get unexpected error has occurred
Used ibrickr to boot iPhone - screen goes green and asks you to use iTunes
Please if anyone can help me, I am going mad.
Baz:mad:
geordisjd
2,442
try this:
1. Take your iPhone out of the docking station while leaving the usb/docking station connected to your computer
2. Power off your phone for at least 10 seconds
3. Put phone back in docking station
4. Press and hold the menu button while powering on your iPhone until u see an icon w an arrow appear on your iPhone
5. iTunes application will give u a new message to restore. Follow instructions.
If it doesn't work download a fresh version of iTunes
barrycompston
Nov 29, 2007
hi
would the fact that the iemi has been changed cause this proble.
it arrived from the states unlocked, and i think they changed the iemi.
cheers
geordisjd
2,442
hi
cheers
I wouldn't know. IEMI, that's something just for Europe, isn't it? 1064 errors and others while trying to restore from iTunes have happened well before there were iPhones in Europe. I had that problem after I modded mine, then tried to install an update which forced me to restore (on my main computer). I went around it by restoring from my laptop.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
The IEMI is different on each phone, at least that is what I was told today. Actually HAWK knows this stuff inside and out, he can shed light on this.
barrycompston
Nov 29, 2007
Hi
Still wont restore
Tried restoring to 1.0.2 and I get an error1
When restoring to 1.1.1 I get error1064
And when I do the normal restore again error 1064
Runnimhibrickr the phone goes green and says update via iTunes.
I have tried changing usb ports,turning pc off,using another pc
The phone is a usa model with upgraded 1.1.2 firmware on it.
When connected to iTunes it shows:
Capacity: n/a
Software Version: n/a
Serial Number: n/a
Phone Number: n/a
Any other help or advise would be great.
Baz:oops:
This is true. Like the Serial No., it's different on each.
- John
Diesel8
Jan 13, 2010
Hello, this is what happened to me from the beginning, before i buy a new computer, i was on my old pc, then i purchased a iPhone 3gs, now i connected it to the pc and it went fine iTunes detected it and all was fine , ok now i bought a new pc i tried to get it working on iTunes i thought it was gonna work normally like the first time, then i got error 1611 , an uknown error occurred...etc.. i was mad lol then i was thinkign to go back to the old pc and restore there, what happened? everything went fine, nice installation and restored it all clean. i turned again the new pc on and tried to restore , same error :( again, i went back to the old pc again and did a complete new installation of vista 64-bit, the first thing i did is to install iTunes, and it was a good installation and it worked, if u go back to another computer or just format everything and install a new fresh copy of vista , the first thing u need to do is to install iTunes , then your iPhone will be restored, if not on the pc your using, just try another computer with fresh installation of OS, and first thing u need to do is to install iTunes .do not install another programs... i just tried it now and it works fine but its not working on the new pc i don't know , but maybe if i install a fresh new OS on it maybe it will work i didn't tried that yet , Good Luck, if u already solved your problem , please let me know . cause i still cant restore it on the new pc . :)
