Error Occurred while mingling data
jnline
Jul 19, 2007
Using Windows XP Pro, Outlook (Office2003) and latest iTunes from Apple.
Brand new PC no other Applications just XP and Office2003.
When I try to sync (just the Calendar) I get the following error:
iTunes could not sync calendars to the iPhone "user"'s iPhone
because and error occurred while mingling data.
Thanks for any help you can provide.
Jnline
uruca
Aug 7, 2007
Fixed error
I got the same error after updating to system 1.0.1, and tried all sort of things like deselecting calendar sync, and reselecting and deleting isync history none of which worked
I did not have much in my calendars in the phone, since last sync, so just clicked in info advanced replace info in the iPhone calendars.
That did the trick and I don't get the error while syncing
sharanam
Sep 12, 2007
fix for "error mingling data"
Jnline
In iTunes, go to iPhone icon, click Info tab, scroll down to "advanced", click on "replace information on this iPhone" for calendar and/or contacts, depending on your problem That should fix it.
northerncal98
Sep 20, 2007
Thank You!
You saved me hours of frustration.
A great community we are!
