ERROR: Package Download Failed...
iSpend
Jan 11, 2008
126
Can't find host.
I'm trying to download from my AppSnapp installer. Never had this problem before. Does anyone know what this means, and how it can be fixed?
Thanks in advance!
Jhors2
Nov 11, 2007
239
Refresh your sources....try again, I've had this problem quite a few times.
iSpend
Jan 11, 2008
126
thanks. But doesn't refresh the sources everytime you open installer?
diverdown
Sep 12, 2007
970
49
NYC
There is a button in installed to refresh sources, I used that and asked me to install an update. Once that update was installed the download errors stopped.
thanks for the info Jhors2...
~S
Jhors2
Nov 11, 2007
239
No Worries :) It does refresh your sources, but sometimes it works better to do it manually, I had the exact same problem but it happened with a mislinked app in installer, after I refreshed it worked fine. :)
iSpend
Jan 11, 2008
126
noooo not "manually". You mean using, say, Fugu?
I'm a novice, so if I can't tap refresh or restore, I'm sunk
How is it done manually?
Jhors2
Nov 11, 2007
239
you go to the sources tab on the very bottom right of installer and at the top there is a refresh button.
iSpend
Jan 11, 2008
126
sounds simple enough, but I'm kinda unsure about upgrading to 1.1.3, and jailbreaking. Seems like so many people are having problems.
Whats been your experience?
Jhors2
Nov 11, 2007
239
It's been awesome, went SEEMLESSLY, the only problem I had is with iPhysics, you have to change the permissions on the file, and I have had some experience working on file systems, but the learning curve isn't steep at all, read around, if you have any problems at all its easy to find a solution. Pm me if you have any problems at all, my youtube, locate me feature on google, ringtones, everything worked fine straight after the jailbreak!
MarcosG
Feb 12, 2008
the refresh trick doesn't work I tried it and nothing. Its been this way the past 3 days. I called my cousin and he's having the same issue. Any other ideas on how to solve this?
Dinger123
Feb 15, 2008
14
West Sussex UK
Hi
I had this problem and found a link advising to "Run installer, goto 'Sources' update sources that you use!
The link to some of the sources changed recently.
Hope this helps!
Dinger
jojo76
Mar 18, 2008
9
refresh failed
Hi eveyone...
I'm having the same problems, i have downloaded a few things and all of a sudden it can't find the host, refreahing doesn't help either it says refreshed failed.
Help...
please
wbrod
Oct 25, 2007
25
Hi eveyone...
Help...
please
Check that u don't have anything in que, i had the same promblem it seens that i had a download waiting in qued, after i removed from que everything was fine. Hope it help
jojo76
Mar 18, 2008
9
thanks i shall try that... can you also tell me how i can see the downloads waiting..?
wbrod
Oct 25, 2007
25
i don't think that can check what you have in queue, just try clearing anything in queue and see if that help
jojo76
Mar 18, 2008
9
I have tired that too.. nothing in que... i still cant refresh sources.. :-(
jfagundo
Sep 14, 2007
31
reinstall community sources.
I tried everything myself with no luck, the thing is I was able to install earlier after upgrading to 1.1.4. Now, no matter what I click on, it gives me the same error.
I can't even reinstall BSD Sub. What the heck is this all about? I don't know what to do.
Thanks. :mad:
jojo76
Mar 18, 2008
9
It doesn't give me the choise to reinstall with community sources, it does with Bsd subsystem, installer 3.01 but then i cant find the host to download.
Yeah I have the 1.1.4 too it's driving me crazy....
Bone
Feb 11, 2008
1,214
Quick question... When yall jailbroke did you set up a new partnership between the phone and computer. I.e new name and everything or did u use the old one?
