Error: Package Size Mismatch (Customize)
TomTomTuning
Aug 10, 2007
196
Camp Hill, PA
Ok..
Woke up this morning and of crouse i had to check for updates.
I knew there was going to be a new update for Customize.
So i downloaded the update for Customize, then i tired to download the update for the Designer Image set. But i get this error
Package Size Mismatch.
I also get this error when i try to download the Sound Set for Customize also.
Any one else having this problem?
z28black98
239
Tulsa, OK
Ok..
yeah I had this problem on a few apps on Monday, retried about 15-30 minutes later and they downloaded just fine. I downloaded the new update for customize as well this morning and had no problems.
try again later on, should work for ya.
kency79
Sep 2, 2007
62
Hamilton,NJ
www.myspace.com
Ok..
that error comes out when you have a weak Internet connection. Try to restart your iPhone and it should be fine.
Ace4261991
Jun 18, 2007
530
when I got this error all I did was press refresh and then just try downloading it again and it would work I've done this several times now no need to wait 15-30 min
sp33d
Aug 28, 2007
I had this problem when I had my autolock set to 1 min. After setting it higher to 3 mins, the problem went away. I guess when some apps take longer than 1 min to install you can't have it autolock on ya.
