Error when connecting iPod car charger to iPhone
natalie
86
Louisiana
www.myspace.com
So I picked up a iPod car charger because I was told this will work with the iPhone.
I plug it in and it gives me an error that says something like "This device doesn't work with the iPhone, would you like to switch to airplane mode?"
But at the same time the battery is up and the charging icon at the top is there. Also after plugged a while the phone gets warm (like phones do when charging). So do ya think it works? I haven't been able to leave it plugged long enough to see.
Quake97
Jul 10, 2007
522
Philly Burbs
I wouldn't be quite so ballsy as the last poster. Does the car charger you bought have the "works with iPhone" sticker on it? If not, then it hasn't been tested. Personally, with a $600 device, I'd use what's supposed to work. If you use something that's not supported and you blow out your iPhone, you're stuck.
Joe
gaspyder
Jan 15, 2012
I have 2 iPod car chargers - when used with the iPhone I get a message that they will not work. What gives?
Jmbaker429
Jun 28, 2010
994
144
35
Some chargers, depending on the output, will not charge all devices. Only certain ones will charge certain generations of iPods,iPhones,iPads.
MrMike6by9
Nov 16, 2008
1,482
119
72
Maryland, USA
Check the screen icon. Often the message means that data, such as audio out, will not work but charging is not impaired.
YMMV
Any impatience you show will only create more stress.
