Error when trying to add Custom Carrier Logo
cccablecompany
Everytime I get to the command line putfile I am getting a iPhone pop up error that closes the command prompt. Do anyone know what can be the problem. I restarted me iPhone and computer. iTunes is also not running. My logo are 55X20 ATT logos.
princess_80854
657
Make sure iTunes and iTunes helper are closed. Also, make sure that you are typing the file names in EXACTLY as it is with the original file and that you are putting them in the correct folder.
For your carrier logo, you would type this command:
cd /System/Library/CoreServices/SpringBoard.app
putfile System/Library/CoreServices/SpringBoard.app/Default_CARRIER_ATT.png
putfile System/Library/CoreServices/SpringBoard.app/FSO_CARRIER_ATT.png
I hope that helps.
cccablecompany
I hope that helps.
I killed iTunes and iTunes helper. I am still getting the same thing.LOOK!
princess_80854
657
Hmm.. Have you tried Manzana (the drag and drop software)? You don't have to type in any commands. You just drag and drop the icons to the appropriate folders within the application.
iPhobos
Jul 25, 2007
201
Make sure that you have added your new carrier logo files into your mod folder. I received that error when i was doing too many things at once and forgot to move them for my editing folder to my iPhone Mod folder.
SevenThirteen
Apr 3, 2008
30
im having the same problem. im using iPhonebrowser and i have my images named Default_CARRIER_ATT.png and FSO_CARRIER_ATT.png. so i know those are right, but when i add them and restart my phone they don't show up..... perhaps i need them in a specific folder?
ArEa_CoDe_415
Oct 4, 2007
537
30
San Francisco
Put them in the ATT_US.bundle folder by going to:
System/Library/Carrier Bundles/ATT_US.bundle
SevenThirteen
Apr 3, 2008
30
yup that did it thanks a lot!
this may be a little off topic, but do you know how i can get an image behind my keypad? i have the file made, i just cant get it in the right place. i got it there once and it fickered like it was there, but then the original keypad showed up again
ArEa_CoDe_415
Oct 4, 2007
537
30
San Francisco
Put the file in MobilePhone.app
Go to Applications/MobilePhone.app
I don't know what to rename the file to make it stay as an image behind the keypad.
