Explain how WiFi works on iPhone?
Nov 6, 2007
14
I have a question about the wifi feature on the iPhone? how exactly does it work.. im getting an iPhone in a few days and i wasn't sure about the safari or the wifi? can someone please explain to me how these features work? and the wifi wont cost money when u connect through it..thanks
termleech
Sep 7, 2007
1,154
McPherson, KS
The Wifi works just like Wifi on a laptop. You connect to a wireless AP (access point) which gives you internet access. If it is a home or work wireless AP, then it won't cost you money, but if you are using a Hotspot like T-Mobile or some others, then it probably will cost you money. It just depends on what you are using.
Any time you have Wifi on, the iPhone will use it for internet and not the Edge.
Hope that answers your questions.
Wi-Fi is absolutely free; of course, you have to pay to have Internet, but you already do that.
You must have a router, and that's it. Under Settings, there is a Wi-Fi panel. When you open it, the iPhone will scan for Wi-Fi routers. When it finds one, you tap it, and you're in.
Marianne
2,326
29
Massachusetts
marianneschultz.com
just remember that not all AP's are free. for example, t-mobile runs wifi hotspots at most starbucks locations, and there is a charge to use their AP's (pay-as-you-go subscriptions or regular monthly charges). if you're really concerned about using wifi on the iPhone, you should check out the wifi offerings at the places away from home that you frequent to see if they're free or not.
