Explain to me SSH install please
Jul 28, 2007
I need some easy instructions of how to install SSH.. all the other instructions are just so confusing i don't know what im doing!:sick:
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
Can't get no easier than this....
Download file from link, Extract the sshKit, run sshify-windows.bat
Follow instructions on screen....your done
http://cre.ations.net/blog/post/howto-install-ssh-on-your-iphone
To gain access on iPhone...Download putty from
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
I downloaded the 1st one from ftp
Go to wifi settings on iPhone and get your ip
load up putty.... type in ip address... and make sure Port is 22
when it asks for login or username.... type in.... root
password, type in .... dottie
Then your in
Jul 19, 2007
9
this is pissing me off! i cant get this to work! i tried putty and WinSCP and it keeps telling me ( Network Error: Permission Denied )
please help
nickfury
Jul 21, 2007
If you have a Mac then use terminal..
Applications>Utilities>terminal
then at the cmd line...
ssh user@ipaddress
user is the user you need to login with and IP address *should* be the address of the phone
it will then prompt you for a password, which I do not know b/c I haven't modded my iPhone......... yet :p
cheers
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
Winscp and i also tried proxy
Make sure you have SCP selected in the dropdown window in WinSCP... Also, try usings Putty.... its not a simple drag and drop like Winscp, but its a start to trying to find out the issue. Also, make sure the port is allowed in your firewall settings.
Jul 28, 2007
Ok here this is what i need to know
I have a mac.. i want to install the NES app on the iPhone.. just tell me what i need to do to do this.. i don't have SSH on my iPhone and i have a mac.. please tell me i need a walkthrough and im kinda new to terminal if you have the time.. please write me back
iBrad
Hmm
Any idea why its not letting me type in the password? I type in root. that goes through, then when i "attempt" to type dottie it doesn't let me type in in...? any ideas?
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
When typing in Linux\Unix, the cursor stays in same position, just type in password and hit enter....your in
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
Theres been tutorials and things of that nature already created, just search for them and your set.
You can also try modmyiPhone.com and go to the Mac forum for modding.
unknownentry
Jul 19, 2007
204
Knoxville, TN
www.iphonesurge.com
Then your in
I can't wait to get home and try this!
