express/34 cover stuck open...
15,385
1,089
is this thing supposed to be spring loaded? I haven't used the slot yet, but i noticed it was halfway open, so the genius inside me decided to poke it, and now it's ALL the way open.
i'd consider taking it back to get a replacement, but i just installed an OEM copy of windows, and it doesn't like switching machines... of course, i do need to head to the Apple store for some other things, so i may see what they can do.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
From what I remember it is supposed to be spring loaded. I'll check for you when I get home...
15,385
1,089
ugh... i may have to exchange this one if i can't fix it... definitely not gonna be easy.
15,385
1,089
i mean it won't be easy to fix it, so i may just end up exchanging... again.
the problem is i'll have to re-bootcamp, reload all of my Windows programs, and Migrate all my mac stuff.
i've already done this a few times, mind you.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
I feel your pain, after going on 4 machines. Maybe the 3rd will be the charm for you.
15,385
1,089
well, the first one was good. just bad timing on my part.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
True. I bought my MBA KNOWING that Tuesday would be an upgrade to the MB's and MBP's. Oh well. Just bring it back and do it right. I know that would bother the hell out of me.
15,385
1,089
it is bothering the hell outa me. i'm going to pull the case apart tomorrow, and if i can't get at the spring to fix, i'll return it.
and my windows is acting rather strangely, so i may have to re-bootcamp anyways... and if i have to do that, i might as well do it on a new computer...
psylichon
Oct 31, 2007
16,591
751
40
Philly
Can't you image your disks to save the hassle of reinstall?
