Faulty downloads?
Loquutis
Jun 27, 2010
293
43
Mississauga
Can anyone tell me why I have this on my iPad Air 2?
It's stuck like this. Nothing is happening and I can't even edit it away. It seems stuck like this. There are even song there that I have never heard of???
And it's only on my iPad, not my iPhone 6.
Any suggestions?
28,365
5,506
Tried it Europa, with no luck. It's still the same.
Do you have anyone else sharing your account (Family Sharing)? If not, try syncing with iTunes on your computer. If that doesn't fix and they are still there in the morning, call Apple and ask to talk to an iTunes Specialist. They can remotely clear your download queue.
Loquutis
Jun 27, 2010
293
43
Mississauga
So....tried to sync with my laptop. No luck. Called the iTunes specialist. 2 and a half hours with the guy and even escalated to his higher up, tier 2 senior advisor. Guess what? No luck. At least nothing easy. His final suggestion was to format and reinstall " as new " . I really did not want to do that. I let him go saying I would do so later, which I MIGHT, but I had no more time to spend at the moment.
We'll see later on.
It's not really causing any other problem with the function of my iPad, so I may just leave it for now. I hate going through all that crap. It just bugs the hell out of me when something is just not perfect with my stuff!
28,365
5,506
We'll see later on.
I had an app download that wouldn't clear about six years ago. It was a large app and it would complete downloading only to start right back over, which resulted in a perpetual download of the 1 GB file. I could pause it, but there was no way to delete it, so I talked to an iTunes specialist and they were able to remove it from my downloads queue remotely. I guess they can't do that any more.
Yeah, I would leave it for a while and see if it eventually clears on its own. It's not worth restoring.
Docd
Oct 16, 2011
650
66
Had something like this, I fixed it by doing a restore from backup. I would at least try this first before a restore as new.
Loquutis
Jun 27, 2010
293
43
Mississauga
Tried to restore from a back up I made just prior to seeing this issue. Same thing. Then again with the first back up I did when I bought the iPad. Same thing?!?!
So....AGH!!!!......
Backed up as new. Just finishing up reloading stuff. So far, so good.
Such a love/hate relationship I have with technology.
Napoleon PhoneApart
Jun 19, 2007
33,444
4,534
Upper Marlboro, MD
So....AGH!!!!......
I have no problem with technology. I love to hate it. :)
