Gimo New Member Nov 7, 2012 #1 Nov 6, 2012 3 0 1 Nov 7, 2012 #1 Can you fax on an iPhone? For example, if I have a document in an app or email, can I fax that? Can anyone recommend a good faxing app?
Lon Evangelist Gold Nov 7, 2012 #2 Jun 5, 2010 2,946 132 63 Alaska Nov 7, 2012 #2 Gimo said: Can you fax on an iPhone Click to expand... I believe the only way you can do it is with a special App and an account. I use eFax, which has a monthly fee, but it works nicely. I can send and receive from iPhone/iPad.
S sonic1519 New Member Nov 7, 2012 #3 Jan 26, 2011 25 0 3 Nov 7, 2012 #3 metro fax is another good one that i use. the app for the iPhone works well to. all though i don't if i can print a fax from it.
iphonewarrior Moderator Moderator Nov 8, 2012 #4 Apr 11, 2008 13,847 702 113 Nov 8, 2012 #4 https://itunes.apple.com/us/app/ifax-send-receive-faxes/id331514859?mt=8
