Few apps already installed no longer working on iOS 8.2
rugved1118
Sep 27, 2013
642
Hello,
There are few apps which are not working ever since i have updated to 8.2. Some of the apps are : Up by jawbone, Book my show, hike messenger, etc.
Can anyone please help me resolve this issue ?
Skuya65
Apr 12, 2015
26
South Dakota
E-mail the developer of the app and tell him the problem. It wouldn't be Apples fault. That's why Apple warned developers to update their apps.
Sent from a very sexy device.... Rawr...
28,365
5,506
Please explain how they are not working. Do they crash upon opening? Do you get an error message?
rugved1118
Sep 27, 2013
642
The above apps crash when you try to open them without giving any error.
These apps were working ever since my cell was jailbroken. Unknowingly, i had opted for factory restore from the iphone which then caused my iphone non-responding.. Seeking your assistance, i did a restore in DFU mode using itunes to bring back my iphone back to normal.
From this incident, these three apps are not working.
28,365
5,506
If they crash upon opening, deleting them by pressing the "X" on the app icon when they are in wiggle mode and reinstalling them should work. I don't think I've ever seen that fail to fix the problem you are having. Try it again and reboot in between deleting the app and reinstalling it.
rugved1118
Sep 27, 2013
642
Done what you have said but there is no change. What could be the possible reason ?
Ledsteplin
Oct 29, 2013
4,817
985
65
Florence, AL
Book My Show had a May 14th update. Maybe it was a bad update. Only one review. It's only optimized for the iPhone 5. But you have 3. Are any optimized for the iPhone 6? It shouldn't make a difference. But with some it does.
rugved1118
Sep 27, 2013
642
Ok, I guess there is some confusion from my part while narrating the issue. So, let me explain in detail :-
I had Jailbroken IOS 8.1.2 on Iphone 5S which then I tried to "erase all content and settings" from the phone. Later on, I realised I shouldn't have done this on a jailbroken phone. It made my iphone got stuck at the boot logo. After seeking advice from the forum, I had to restore using iTunes with an update of iOS 8.2. Ever since I am on 8.2, these three apps are not working. a couple of updates for these apps had come up which I updated also hoping to work.... but hard luck.
Another problem is, I am unable to backup my iphone on icloud / itunes too. It displays an error "iTunes could not back up the iPhone because the backup could not be saved on the computer". I have also made sure that my backup is not done on icloud.
I would really appreciate if anybody could help me resolve this issue.
28,365
5,506
To fix the app crashing problem:
Delete the three apps from your phone by pressing the "x" while they are in wiggle mode. Now do a hard reset on the phone by pressing the home button and the power button at the same time. Release both buttons when you see the Apple logo. Now go to the App Store and download the apps again.
To fix the backup problem:
Delete your existing iPhone backup files from Windows. After deleting them, try to make a new backup in iTunes. They are located here on Windows 7:\Users\(username)\AppData\Roaming\Apple Computer\MobileSync\Backup\
Let me know if these steps do not fix the problems and we will move on to the next steps.
rugved1118
Sep 27, 2013
642
I have followed steps which you have mentioned but the problem still persists.
28,365
5,506
1. Now delete the entire backup folder in iTunes and try it again.
2. Go to Settings > iCloud > Storage > Manage Storage > Documents & Data > Are any of the three apps listed here? If they are, select Edit and then delete the info. Next delete the apps again and then reinstall them.
rugved1118
Sep 27, 2013
642
Still the same
Tried deleting and reinstalling those three apps, but the problem still persists.
My handset is still under warranty, May I visit app store for this issue ?
28,365
5,506
Still the same
No, I wouldn't take it to Apple. There is still a lot of troubleshooting you can do. You might need to reinstall iTunes to fix it.
First off, are you sure you have enough free space on the drive for the iTunes backup?
Was there any app info to delete in iCloud?
rugved1118
Sep 27, 2013
642
Well, updating latest itunes might solve this problem. But will it resolve apps issue also after reinstalling n updating ?
I have approx 300 gb space on the drive.
I hace cleared everything from manage storage.
