file locations
drogie123
Jan 4, 2008
23
hi its my first post here...
i was wondering if anyone could tell me where the files the customize app are located... mainly its the sound set and the carrier logos i am looking for. ive read other posts which show the locations of the defalts but its the customize stuff im looking for
cheers in advance
Chris
Dec 13, 2007
25
utah
cheers in advance
Chris
here is a list that I have been collecting
Important Paths
Note: FSO images are shown on the homescreen against a black background, Default are shown inside apps against a gray background
Custom Icons
/Applications/*.app/icon.png (64x64)
Ringtones
/var/root/Library/Ringtones
SMS Bubbles (43x32)
/Applications/MobileSMS.app/Balloon_1.png and Balloon_2.png
Battery (264x129)
/System/Library/CoreServices/SpringBoard.app/BatteryBG_1.png (numbered 1-17)
Carrier Logo
/System/Library/CoreServices/SpringBoard.app/Default_CARRIER_ATT.png (44x20)
/System/Library/CoreServices/SpringBoard.app/FSO_CARRIER_ATT.png
System Sounds
/System/Library/Audio/UISounds
Signal (19x20)
/System/Library/CoreServices/SpringBoard.app/FSO_0_Bars.png (numbered 0-5)
/System/Library/CoreServices/SpringBoard.app/Default_0_Bars.png (numbered 0-5)
/Applications/Calculator.app/
/Applications/Maps.app/
/Applications/MobileCal.app/ This is the calendar.
/Applications/MobileMail.app/
/Applications/MobileMusicPlayer.app/
/Applications/MobileNotes.app/
/Applications/MobilePhone.app/
/Applications/MobileSafari.app/
/Applications/MobileSlideShow.app/icon-Camera.png
/Applications/MobileSlideShow.app/icon-Photos.png
/Applications/MobileTimer.app/ This is the clock.
/Applications/Preferences.app/ This is Settings.
/Applications/Stocks.app/
/Applications/Weather.app/
/Applications/YouTube.app/
If you want to replace your battery icons they are at this path:
There are 17 images numbered 1 through 17 like this:
cd /System/Library/Frameworks/TelephonyUI.framework
These are the Aqwoah keyboard files. To install, transfer the Keyboard-Common.artwork and Keyboard-Latin.artwork files into /System/Library/Frameworks/UIKit.framework/
The location of the Edge icons are /System/Library/CoreServices/SpringBoard.app/
