File Locations
tommc4
Aug 2, 2009
Does anyone know the file locations/naming for the iPhone backup files? I had an issue this week with a program that corrupted my network settings (Onavo) and I had to do a DFU reset, then add all of my apps back one at a time. Lost a LOT of data. I figure I should save that one file I made after I fixed the problem, for time savings in the future...
Any info/help would be appreciated! Thanks to everyone in advance.
Windows: C:\Documents and Settings\name of user\Application Data\Apple Computer\MobileSync\Backup
Mac: /Library/Application Support/MobileSync/Backup
For future reference, you can just right click on your phone in the left panel, choose restore from backup and select an older backup.
tommc4
Aug 2, 2009
Thank you SO much. I know about the backups, but it was an app (Onavo) that I deleted, but it did NOT undo the changes it made to my phone's settings. So a restore was worthless. I had to DFU the phone and reinstall EVERY APP because of it. Stay away from ONAVO if you use Netflix or Hulu!
Thanks again for the locations!
Tom
