file manager without using internet
bemania
May 26, 2008
14
29
Switzerland
www.meridia.ch
Hi,
I'm live in a dormitory with only stationary computers, so there is no possibility to access it with sftp (no wireless) or to install any programs (except for portable apps).
i am willing to install some new summerboard themes onto my iPhone (fw 1.1.4). but to install them i would need a way to access my iPhone.
is there a way to access my iPhone?
looking foreward to your answers,
bemania
enigmanic
Jun 27, 2007
513
Hi,
bemania
If you're on Windows, use ibrickr: http://cre.ations.net/creation/ibrickr
I know you said you don't have wifi, but are you able to access Installer using your phone's data plan? (Here in the US, we have Edge). If you can access Installer, you'll need to install the ibrickr fix (or else ibrickr wont recognize your phone as being jailbroken). To do so, add this to your installer source: http://iPhone.unlock.no
...then install the "ZiPhone iBrickr fix", located under Unlocking Tools.
Also, installer already has some pre-made Summerboard themes. Of course, if you want to mix and match your own, you'll have to use iBrickr or something similar.
