Finally Jailbroke and now lost
coasts
Jul 15, 2007
2,026
New York, NY
www.lomohomes.com
on a mac, running 1.1.4 purchased as 1.1.1, with ATT, jailbroke using ZiPhone.
now im in installer, looking at all the funky things you folks have been talking about for months and can't manage to get anything to work. many apps claim to require 1.1.3 or older firmware. i don't want to "downgrade my baseband".
what can i do to see some changes, especially using "Customize", "Summerboard" and oh, oh...that piano one.
OJ - apologies in advance...search button is broken. i called for service.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
For getting Summerboard and others to agree to install, I suggest using x999x's little tweak for that purpose, found on his Fight Club source, which is at:
http://dezign999.com/repo
I don't use Customize, so haven't followed latest fixes for that - but I'm sure I've seen some mentioned around here.
The Pianist app should install fine on 1.1.4 -
coasts
Jul 15, 2007
2,026
New York, NY
www.lomohomes.com
thanks patrick. ive made a bit of progress but nothing visible yet. at least i got a new icon to appear when installing "Ants". i'm in process of figuring out Summerboard. it all looks so easy on Installer.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Were other apps program icons not showing up for you? Certain apps - e.g. BSD Subsystem, OpenSSH - do not add home screen icons.
coasts
Jul 15, 2007
2,026
New York, NY
www.lomohomes.com
thats right. only Ants added a homescreen icon, but then when i clicked it, i could only change the settings. i didn't see one ant!
im really trying to figure out Summerboard. i now see how to change one of their pre-installed Themes, but not sure how to add an Installed theme to the list.
appreciate the help, yeah.
dobymax
Oct 19, 2007
238
question....
coasts - what do you have cut on and off in SMB for this to work? I'm lost too.
coasts
Jul 15, 2007
2,026
New York, NY
www.lomohomes.com
doby, im not sure what i did differently. first, be sure that you have downloaded "Summerboard" from Installer > System, not just various "Themes" from the Themes (Summerboard) section.
after that, you should get SMB Prefs icon on your homepage. if you knew all that already, sorry. i didn't. try Blueprint and see if that one works. i tried Icarus and it didn't.
dobymax
Oct 19, 2007
238
I have all of that dl'd. I try it out tonight. Thanks.
daycheck
Feb 27, 2008
157
Logan utah
www.tosque.com
yeah! ;)
Cool, good job. Now you'll be hooked, never letting a theme last more than a couple weeks before you get itchy ...:)
yeah I am new to this "jailbreaking" to... and hooked is an understatement, it's like crack cocaine..
i change my theme very other day.. LOL
