Finger scanner does not work when charging since 7.1 upgrade
showguy
Dec 2, 2007
769
Long Island, NY
The title pretty much says it all. The Touch ID finger scanner does not work when charging since 7.1 upgrade. I never noticed this before.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Apparently, the iPhone 5s Touch ID not working while connected to a power source isn't a new issue specific to iOS 7.1. This Apple discussion thread offers some curious advice.
The problem is with the ossalation of the power socket that the phone is plugged into. Try using it on a none shared plug socket or extension cable. I have the same problem when the voltage is not consistant to the phone.
I'd be curious to know if it works when following this suggestion.
showguy
Dec 2, 2007
769
Long Island, NY
It's plugged directly into a walk outlet using a Apple original cable.
Sent using iCafe app
showguy
Dec 2, 2007
769
Long Island, NY
Ok. This is weird. I just plugged it into an Apple charger with an Apple cable and it worked. I was using a griffin charger with Apple cable. I guess Apple and griffin sometimes don't like to share a sand box.
rambo47
Apr 4, 2010
528
79
Northern NJ
Mine works when connected to a car charger. It's a micro-USB charger with the little Lightening Port adapter. The only time it doesn't work is after a restart. Then you have to manually (ugh!) type in the unlock code. So 2012! :)
Jan 13, 2014
14
That is not meaning it doesn't work or malfunction. U have to key in the code is actually one of its security feature each time the phone restart. It was design as that way.
MrMike6by9
Nov 16, 2008
1,482
121
70
Maryland, USA
Funny, I haven't noticed any difference in performance on or off charge. I often check my phone, on charge, while laying sleeplessly in bed in the middle of the night.
YMMV
