FirstClass Email Client
shillingem
Jun 28, 2007
54
Greensboro, NC
I was able to get firstclass working on my iPhone and thought some of you might want this as well...
Here are the settings that you will need:
Incoming Mail Server:
Host Name: fc.(your domain name here).(net, com, org....)
User Name: login for first class (make sure it is your login name not your email, these are each different for me.)
Password: ********
Outgoing Mail Server:
Host Name:fc.(your domain name here).(net, com, org....)
User Name: (none)
Password: (none)
Make sure that SSL is turned off. You won't be able to select that option but when you save the settings and it try's to verify your setup it will ask you if you want to turn SSL off. Answer YES! TWICE!
Let me know if anyone used this.
-E
sergio81
Mar 3, 2008
question
What type of email do you have? I work for the school system and i am not able to get it to work like u did. do you have any other ideas?
Password: ********
User Name: (none)
Password: (none)
-E
shillingem
Jun 28, 2007
54
Greensboro, NC
If you are using the firstclass client to check your email you should be able to use fc.bal.henderson.k12.nc.us. That would be just a guess though. I checked with my network admin and they told me that I was able to use IMAP settings to access our school email. Hope this helps.
jreid
May 14, 2008
first class red flags disappear
those were great instructions to get first class email on my iPhone! it was so easy and worked no problem. the only issue i have is that as soon as the email is sent from my school's server to my iPhone, the red flag on my school email disappears, so i don't always know when i have new email at work. any ideas or suggestions how to remedy that?
thanks!
Password: ********
User Name: (none)
Password: (none)
-E
May 17, 2008
I just tried these settings on my iPhone, but I receive the error that no Incoming Server was found. Is there something that I am missing or do I need to perhaps contact our Server Manager ? Someone please let me know! :(
Password: ********
User Name: (none)
Password: (none)
-E
Jul 14, 2008
FC mail worked for me, can we sync contacts or calendar?
Thanks to your instructions, I have FC mail on my iPod touch. Don't ask me why, I use a Blackberry as well, but it's fun. :) But I'm wondering if there's any way I can sync the FC calendar or contacts as well?
Thanks!
wdy7hntr
Jul 18, 2008
Am I missing a step?
What version of FirstClass client did you download?
Password: ********
User Name: (none)
Password: (none)
-E
phinney6
Jul 18, 2008
thanks for your help
I followed your directions and it works great. Thank you a ton. I thought I was going to have to switch email programs. Satisfied in Seattle:laugh2:
Password: ********
User Name: (none)
Password: (none)
-E
phinney6
Jul 18, 2008
How can I turn off SSL on my iPhone? I got FirstClass to work when I set it up, now it I cannot get it to open.
Password: ********
User Name: (none)
Password: (none)
-E
Jul 21, 2008
not able to connect but I may be missing a piece
Thanks for making the attempt here. I need your help, too. I have a new 3G iPhone and can get through most of your settings instructions, but I may be missing something since the connection isn't working.
When I set up a client on my laptop this is the info I see in the settings window
Address: home.fc
Server: emc@fwps.org
So, can you help me because it would be great to have these mails....? in your entries below what will I enter as the incoming and outgoing hosts?
Password: ********
User Name: (none)
Password: (none)
-E
shillingem
Jun 28, 2007
54
Greensboro, NC
To answer a few of your questions in one post:
I am currently using FC 9.0, but haven't found a way to sync my calendar.
The address listed below isn't needed, this is only for your computer.
Address: home.fc
The server below I am guessing is your email address?!?
The incoming host and outgoing host will be as follows...
Incoming: fc.fwps.org
Outgoing: fc.fwps.org
***The Key here is to make sure you use the correct login name. Mine is shillie not ericshilling like my email address says.
To answer the question about SSL once you have the account setup, click ....
-settings/mail, contacts, calendars/(the name of the FC account)
-scroll to the bottom and click advanced
-scroll to the bottom and select OFF for use SSL
-then keep pressing the back button
Hope this helps,
~E
Jul 21, 2008
my typo on the server - I tried putting fc on the front of the server name
I meant to put emc.fwps.org as the server (no @ in it). My address for this system is dworcest@fwps.org. I tried everything you suggested using first fc.emc.fwps.org and then tried leaving off the fc. - emc.fwps.org as the servers, but couldn't get the connection going. The iPhone 3G also gives the options IMAP or POP and I tried both. Would the port number have anything to do with this? Thanks for your help.
Address: home.fc
shillingem
Jun 28, 2007
54
Greensboro, NC
I have mine setup using IMAP and i used the server shown when i log in as fc.greensboroday.org
If I were you I would try emc.fwps.org as the server incoming and outgoing. You might want to check with your network Admin to see if you have IMAP capabilities on your server.
If anyone has been successful with FirstClass on the new iPhone 3G and software 2.0, give me a shout. I can connect to the first class server but I can't access my inbox. Every other folder is fine just not the Inbox.
~E
evalyn
Sep 4, 2008
I'm having similar problems with my iPhone 3G. After a while, I see this message: "Cannot Get Mail" and "The connection to the server 'fc.newbraunfels.txed.net' failed"
Any help?
Oct 26, 2008
I wasn't able to get this to work either. I think it is really close to working because when I go to the account I've made I can see the topics of the different times I have in my First Class email. For example, it reads "calendar," "curriculum discussions." However, when I try to go into my inbox, it says that the connection to the server failed. Any ideas? (is the incoming and outgoing server address the same?)
