Fix for apollo 1.1.3
kariya9mdoa
Oct 26, 2007
80
just ssh into your iPhone using winscp or transmit (mac) and look for etc folder and then the file called host open it with a editor and add this at the bottom of the text in a new line
64.12.161.185 login.oscar.aol.com
64.12.161.185 login.messaging.aol.com
65.54.239.140 messenger.hotmail.com
65.54.239.140 dp.msnmessenger.akadns.net
65.54.179.216 nexus.passport.com
65.54.179.216 nexus.passport.com.nsatc.net
65.54.183.203 login.live.com
65.54.183.203 login.live.com.nsatc.net
65.55.128.48 spaces.live.com
209.85.163.125 talk.google.com
209.85.163.125 talk.l.google.com
it works did it last night and now apollo and AIM messenger work with this
HappyModding
kariya9mdoa
Oct 26, 2007
80
don't know
i am on a mac and i just opened it with text editor so i am guessing on yours maybe wordpad but don't use Word because it puts other characters in you don't need.
If this is wrong please someone correct me.
HappyModding
rtgc2003
Oct 9, 2007
105
DFW,TX
I found a file that says hosts not host is that it do i just add that to the end or what
kariya9mdoa
Oct 26, 2007
80
Yeah thats it
just add it to the end
HappyModding
mletang
Jan 23, 2008
120
NYC
www.NYCpetforum.com
This isn't working for me, I'm not sure if i'm doing it right. I don't have the file host, the one i have says hosts. Does that make a difference? The last line in the hosts file is:
::1 localhost
64.12.161.185 login.oscar.aol.com (this is where i started the address)
kariya9mdoa
Oct 26, 2007
80
yeah sorry the file is hosts and what eva the last line put this under that an restart your phone and it will be fixed
Sorry again
HappyModding
Johny5
Aug 4, 2007
39
St. Louis, Mo
Sorry again
HappyModding
No joy here either...
Does it matter if I cut and paste? Each should be a separate line as in the original post, correct? Any advice. I'm on a mac using cyberduck and text edit. The file appears to have saved correctly when I check.
J5
kariya9mdoa
Oct 26, 2007
80
This is the file
I have uploaded the file hosts just unzip and see if yours looks like this if not just use this.
mobilehavoc
Jul 12, 2007
156
Actually you don't even have to do that..just make sure the /etc/hosts file has full read/write permissions and then install Apollo. It'll automatically add the entries it requires.
You can either do this via SSH or Term-VT100:
cd \etc
chmod 666 hosts
Now install Apollo (or I'm assuming MobileChat) via Installer and they should work fine.
Johny5
Aug 4, 2007
39
St. Louis, Mo
Thank you both. I used the zip folder and my .mac logon is now working, but not hotmail? I would appreciate it if one of you would tell me how to set permissions on a mac. I had done this a few times early in my iPhone modding career, but was on a windows box. I have converted to a mac and am not sure how to perform this action now.
Thanks again,
J5
kariya9mdoa
Oct 26, 2007
80
If you want to set permissions for a file in iPhone, lets say your in transmit and you are in your file system hold ctrl and click then go to get info and you will see permissions there.
Thats it
HappyModding
seanwes
Feb 13, 2008
1,667
San Antonio, TX
I added exactly what you said to the hosts file, and replaced the old one on my phone, and still receive the server authentication error.
kariya9mdoa
Oct 26, 2007
80
some times it does do that you have to turn off and turn on again and when that happens down the bottom it should say stuff like "handshaking and connecting" it does sometimes take a few tries to get it mine does exactly the same but this is only until the sdk comes then i am sure we will see a lot more chat programs.
HappyModding
seanwes
Feb 13, 2008
1,667
San Antonio, TX
HappyModding
great, i got it to connect now, thanks. :)
