Fix for Edge Blue Box
Doby45
Aug 21, 2007
543
Powder Springs, GA
Have we found out why it will switch from the normal Edge icon to the bland blue box? Is it a difference in signal strength or having a signal or not. Know what I mean? There has to be a reason there are different icons.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
Search. I think I remember a thread months ago about this. I think that the phone is accessing edge while roaming when its the bland blue box. I think.
Doby45
Aug 21, 2007
543
Powder Springs, GA
Actually thanks for jogging my memory. I just did a search and it is the bland blue box when it is using GPRS and the E is naturally when it is on EDGE. Thanks for the 411. Running "fix" now.
