Fix for SwirlyMMS 1.1.3
kariya9mdoa
Oct 26, 2007
80
This is to get the settings to save
Just ssh into your iPhone using Term-vt100 and then do this.
cd /Applications
chmod +s SwirlyMMS.app/SwirlyMMS
chown root:wheel SwirlyMMS.app
This works
HappyModding
Jun 7, 2007
545
Queens, NY
cd /Applications
This works
HappyModding
i cant login using term vtoo...incorrect password.....isn't it user root, pw. alpine?
kariya9mdoa
Oct 26, 2007
80
yeah thats the password if you are on 111 and above but sometimes term didn't work for me so i uninstalled and reinstalled and it worked or you can use terminal if you are on a mac. And make sure you have ssh on and your wifi connection.
Jun 7, 2007
545
Queens, NY
found the fix for term vt100
kariya9mdoa
Oct 26, 2007
80
Let me know if it worked or if you need help.
HappyModding
