Fix home screen to fit in boxes?
slayer666
Aug 13, 2009
122
Hi is there anybody that can fix this home screen to fit in the icons properly within the boxes? iOS 7 5S
Sent using iCafe app
B-DoGGy
Jun 20, 2010
41
11
Roanoke VA
Can you put it as your home screen and take a screenshot? Most of us are sitting here wondering why it doesn't fit just by looking at it.
EDIT: I don't have an iPhone yet so maybe others can help you more but as a longtime ios user it seems to look perfect, unless ios 7 changed their icon sizes?
15,384
1,089
yes, iOS7 icons sizes and shapes have changed slightly.
slayer666
Aug 13, 2009
122
Here is the screen shot of my home screen
B-DoGGy
Jun 20, 2010
41
11
Roanoke VA
That's a pretty sweet wall, if you get it fixed I'd like to use it if you don't mind. Have you played around with cropping any to see if you can get it closer without the status bar being effected?
It "looks" fixable but with out the original I wouldn't be able to guess what has to be done.
slayer666
Aug 13, 2009
122
Just for s**** and giggles try to see if the pic I attached works. It probably won't but it was worth a try.
Just tried it and it doesn't work unfortunately
slayer666
Aug 13, 2009
122
Europa your the best thanks heaps for that
